| 0002673 | FreeCAD | Bug | public | 2016-08-15 22:08 | 2016-12-19 16:41 |
| Reporter | gitamani | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002673: Not memorize the rotation | ||||
| Description | Does not memorize the rotation of an object created with the Part mode. When you change the position of the rotation back to the previous value. | ||||
| Steps To Reproduce | In Part mode insert a new cylinder. On Rotation rotated 45 ° in Y-axis, and click OK. On Position I move on y of 1 mm. The rotation of the cylinder is reset to 0 °. | ||||
How do you set the rotation & movement? Over the property editor or over the Placement dialog? |
In the property editor. |
I cannot confirm this. Btw, where on the property editor can you click an "OK" button? |
The error exists either clicking OK that before on Apply and then OK. |
I added the video show the problem. And one Very annoying. It makes you lose a lot of time is saved Because the rotation must clear the subject or choose another one and then select it again. |
That's mainly an update problem because the preview of the placement values shows the correct axis but not the sub-element. |
| 2016-08-15 22:08 | gitamani | New Issue | |
| 2016-08-16 17:02 | wmayer | Note Added: 0007279 | |
| 2016-08-17 07:45 | wmayer | Status | new => feedback |
| 2016-08-18 02:08 | gitamani | Note Added: 0007283 | |
| 2016-08-18 02:08 | gitamani | Status | feedback => new |
| 2016-08-18 13:55 | wmayer | Note Added: 0007284 | |
| 2016-08-18 16:30 | gitamani | Note Added: 0007285 | |
| 2016-11-28 00:04 | gitamani | File Added: freecad.ogv | |
| 2016-11-28 00:10 | gitamani | Note Added: 0007494 | |
| 2016-11-28 12:23 | weddingbackdrops | File Added: W04-280x280.jpg | |
| 2016-12-01 11:39 | wmayer | File Deleted: W04-280x280.jpg | |
| 2016-12-18 18:07 | wmayer | Note Added: 0007530 | |
| 2016-12-18 18:07 | wmayer | Status | new => confirmed |
| 2016-12-19 16:33 | wmayer | Changeset attached | => FreeCAD Master master bb7e662e |
| 2016-12-19 16:41 | wmayer | Status | confirmed => closed |
| 2016-12-19 16:41 | wmayer | Resolution | open => fixed |
| 2016-12-19 16:41 | wmayer | Fixed in Version | => 0.17 |
