| 0002675 | FreeCAD | Bug | public | 2016-08-16 16:42 | 2016-08-17 02:45 |
| Reporter | DeepSOIC | Assigned To | yorik | ||
| Summary | 0002675: Transparency is lost upon save-load | ||||
| Description | For objects set as transparent, the transparency is not correctly restored when loading project. The value of property is restored, but the object is shown opaque in 3d view. | ||||
| Steps To Reproduce | 1. Part Cube 2. Set transparency to say 90, by editing Transparency property on view tab of property editor. The transparency is applied as expected. 3. Save project, close, reload. The cube is displayed opaque, even though Transparency property of Cube still says 90. OR open the attached project. The cube should be 90% transparent, but is displayed opaque. | ||||
| Additional Information | forum thread: http://forum.freecadweb.org/viewtopic.php?f=3&t=17034 OS: "openSUSE Leap 42.1 (x86_64)" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7833 (Git) (Packman) Build type: Release Branch: master Hash: d9b7a5fbbf7c444c7ab94473a11449840a946313 Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8226 (Git) Build type: Release Branch: master Hash: 892271c0d5c421b4fe3a690c8c0c3f7e73dc22f5 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 Probably a related problem: object becomes opaque when I change its color in property editor. | ||||
I'm afraid that's caused by my commit here... https://github.com/FreeCAD/FreeCAD/commit/43e0834fb44261b7f056a1cd463feedb19ac99e7 I think we should remove line 660 (if only one color in DiffuseColor, then use global object transparency). |
| 2016-08-16 16:42 | DeepSOIC | New Issue | |
| 2016-08-16 16:42 | DeepSOIC | File Added: transparency-test-2.FCStd | |
| 2016-08-17 02:41 | yorik | Note Added: 0007280 | |
| 2016-08-17 02:45 | yorik | Changeset attached | => FreeCAD Master master 3dd3461a |
| 2016-08-17 02:45 | yorik | Assigned To | => yorik |
| 2016-08-17 02:45 | yorik | Status | new => closed |
| 2016-08-17 02:45 | yorik | Resolution | open => fixed |
