| 0002681 | FreeCAD | Bug | public | 2016-08-25 13:49 | 2016-08-26 14:25 |
| Reporter | paomod | Assigned To | yorik | ||
| Platform | apple | OS | macosx | OS Version | 10.11.5 |
| Summary | 0002681: Clone misplaced when replacing original | ||||
| Description | I create the clone of an object. I scale the clone. I translate the original object in a new position. The clone is slightly translated. | ||||
| Steps To Reproduce | Open a new document. Create a Cylinder centered at the origin. (Cylinder) Duplicate it to have a reference. (Cylinder001) Clone it. (Clone of Cylinder) Scale the clone (e.g. scale x=0,99, scale y=0,99,scale z=1). Cylinder and Cylinder001 are completely coincident, Colne of Cylinder is positioned with the center in teh origin, with a smaller diameter w.r.t. the others. Translate Cylinder with "Edit->Placement" of, e.g. x=20, y=15 (choose any translation you like). The Cylinder is translated to the new position, Cylinder001 remains centered at the origin, Clone of Cylinder is automatically re-centered in a position slightly different from the origin (use Cylinder001 as reference for the center). | ||||
| 2016-08-25 13:49 | paomod | New Issue | |
| 2016-08-25 23:23 | yorik | Assigned To | => yorik |
| 2016-08-25 23:23 | yorik | Status | new => assigned |
| 2016-08-25 23:24 | yorik | Note Added: 0007296 | |
| 2016-08-26 14:25 | yorik | Changeset attached | => FreeCAD Master master f1bc0ce2 |
| 2016-08-26 14:25 | yorik | Status | assigned => closed |
| 2016-08-26 14:25 | yorik | Resolution | open => fixed |
