| 0002685 | FreeCAD | Bug | public | 2016-08-30 09:14 | 2016-09-05 02:13 |
| Reporter | Berner | Assigned To | yorik | ||
| Platform | 64bit amd | OS | Linux 64 bit | OS Version | Debian 8.5 |
| Summary | 0002685: Luxrender failed with Syntax-Error | ||||
| Description | I have tried to render my project with luxrender and got a syntax error on line 126. The Error Messages in Luxrender-Console are: 2016-08-30 10:29:47 Info: 0] Freeing resources. [2016-08-30 10:29:47 Info: 0] Freeing resources. [2016-08-30 10:29:47 Info: 0] Server requests interval: 180 seconds [2016-08-30 10:29:47 Info: 0] Loading scene file: '/tmp/tmpTGB9kM.lxs'... [2016-08-30 10:29:47 Severe error: 47] Parsing error in file '/tmp/tmpTGB9kM.lxs' at line 126: syntax error AttributeBegin # "Lux_Rectangle" Transform [1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1] NamedMaterial "FreeCADMaterial_Lux_Rectangle" Shape "mesh" "integer triindices" [] <------ Syntax error on this line "point P" [] "normal N" [] "bool generatetangents" ["false"] "string name" ["Lux_Rectangle"] AttributeEnd # "" OS: Debian GNU/Linux 8.5 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16. Build type: None Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | Load my haus-project and try to render it with luxrender. I dont have this problem with povray! | ||||
I'll have a look |
Ok the problem is that you included in your lux project objects that have no face (for ex. the "Rectangle" object). But there is a bug anyway, these should not be exported as invalid objects as they are now, and should be skipped. |
| 2016-08-30 09:14 | Berner | New Issue | |
| 2016-08-30 09:14 | Berner | File Added: haus.fcstd | |
| 2016-08-31 00:04 | yorik | Note Added: 0007299 | |
| 2016-08-31 00:04 | yorik | Assigned To | => yorik |
| 2016-08-31 00:04 | yorik | Status | new => assigned |
| 2016-09-05 01:49 | yorik | Note Added: 0007305 | |
| 2016-09-05 02:13 | yorik | Changeset attached | => FreeCAD Master master 1a0efaa4 |
| 2016-09-05 02:13 | yorik | Status | assigned => closed |
| 2016-09-05 02:13 | yorik | Resolution | open => fixed |
