| 0002696 | Draft | Bug | public | 2016-09-14 18:46 | 2016-10-06 14:24 |
| Reporter | rhorton | Assigned To | yorik | ||
| OS | windows | OS Version | 10 | ||
| Summary | 0002696: DWire entry issue | ||||
| Description | When using the DWire entry tool to add a new DWire, I found that entering a "-" symbol to enter a negative number made the right hand side indicator turn to a red cross, before a number was entered, whereupon it went green again. This was OK, BUT: when it went red, the previously entered point was deleted from the drawing. | ||||
| Steps To Reproduce | Open a new file. Select Draft toolset. Orient the display so you can see the 2d grid on the XY plane. From Create Objects, select DWire. The DWire entry system displays. Make Relative and Filled checked. Enter a first value of 0,0,0 and click "Enter point" Enter a second value of 50,0,0 and click "Enter point". You should see a horizontal line on the grid. Enter a third value of 0,10,0 and click "Enter point". You should see a vertical line on the right of the horizontal line. Now, enter a fourth value of -40,0,0 and click "Enter point". Expected behaviour would be a new line moving left from the top of the second line. What actually happens is when you type the "-" key in the x box, the indicator turns red and the second line is deleted. | ||||
Indeed something strange happening... I'll investigate |
The problem was that the built-in Ctrl+Z "undo" shortcut was apparently triggered by the "-" input, no idea why. Anyway, I now removed that Ctrl+Z shortcut entirely, since the underlined shortcut that appears on the undo button works perfectly. |
| 2016-09-14 18:46 | rhorton | New Issue | |
| 2016-09-14 22:37 | yorik | Note Added: 0007321 | |
| 2016-09-14 22:37 | yorik | Assigned To | => yorik |
| 2016-09-14 22:37 | yorik | Status | new => assigned |
| 2016-10-06 14:23 | yorik | Note Added: 0007344 | |
| 2016-10-06 14:24 | yorik | Changeset attached | => FreeCAD Master master 7ef31e49 |
| 2016-10-06 14:24 | yorik | Status | assigned => closed |
| 2016-10-06 14:24 | yorik | Resolution | open => fixed |
