| 0002697 | PartDesign | Bug | public | 2016-09-14 21:42 | 2016-12-28 16:34 |
| Reporter | alpha6 | Assigned To | wmayer | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002697: Can't create a pad or a pocket on the detail | ||||
| Description | Hello. I can't create a pad or a pocket on the detail. If I try to create one, the detail disappears from the screen and after I press "OK" button I see the window with text "Error". And the same way I get a message "Document::recompute: The graph must be a DAG." on my console. I use FreeCad daily build from ubuntu ppa. The FreeCad version is: OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8405 (Git) Build type: None Branch: master Hash: 05a25967bd756405a688526f4b63c5fad6e71378 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | 1. Open the attached document 2. Create sketch on any surface 3. Draw circle or hexagon 3.a. If I draw a rectangle - FreeCad falling down with error message: freecad-daily: SoGroup.cpp:292: virtual SoNode* SoGroup::getChild(int) const: Assertion `(index >= 0) && (index < this->getNumChildren())' failed. Aborted (core dumped) 4. Create pad or pocket from the sketch 5. The detail disappear from screen | ||||
| Additional Information | If I remove the Pocket006 and his sketch and create it again - everything work fine. | ||||
The following forum post describes, how to produce a document with such an error: http://forum.freecadweb.org/viewtopic.php?f=3&t=17995#p141473 Ulric |
With the following Python snippet the circular dependency can be fixed: |
The attached change set (commit 70040818) fixes the reason to create the circular dependency. |
The crash is not reproducible (any more). But the non DAG issue is fixed. |
FreeCAD: master 70040818 2016-12-28 17:05:20 Details Diff |
avoid to create a circular dependency when modifying an existing pad or pocket operation |
Affected Issues 0002697 |
| mod - src/Mod/PartDesign/Gui/TaskFeatureParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskSketchBasedParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ViewProvider.cpp | Diff File | ||
| 2016-09-14 21:42 | alpha6 | New Issue | |
| 2016-09-14 21:42 | alpha6 | File Added: hotend_holder_v2.fcstd | |
| 2016-10-16 14:46 | ulrich1a | Note Added: 0007385 | |
| 2016-12-28 16:17 | wmayer | Note Added: 0007552 | |
| 2016-12-28 16:18 | wmayer | Changeset attached | => FreeCAD Master master 70040818 |
| 2016-12-28 16:19 | wmayer | Note Added: 0007553 | |
| 2016-12-28 16:34 | wmayer | Note Added: 0007554 | |
| 2016-12-28 16:34 | wmayer | Status | new => closed |
| 2016-12-28 16:34 | wmayer | Assigned To | => wmayer |
| 2016-12-28 16:34 | wmayer | Resolution | open => fixed |
| 2016-12-28 16:34 | wmayer | Fixed in Version | => 0.17 |
