| 0002701 | FEM | Bug | public | 2016-09-18 01:59 | 2016-09-27 17:35 |
| Reporter | Dieter Nuetzel | Assigned To | |||
| Platform | x86_64 | OS | Linux | OS Version | 4.7.4 |
| Summary | 0002701: 'Load an FEM 2D / 3D example analysis' do not work with 0.17 git | ||||
| Description | 'Load an FEM 2D example analysis' didn't show the FEM triangles for several weeks, now. 'Load an FEM 3D example analysis' didn't show anything for several weeks, now. OS: "openSUSE 13.2 (Harlequin) (x86_64)" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8403 (Git) (Packman) Build type: Release Branch: master Hash: f2f9a938a7fc07b7155d1a695d40ef340b227147 Python version: 2.7.12 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev | ||||
| Steps To Reproduce | Click onto the topic under 'Beispiel-Projekte' | ||||
I guess you are talking about the links of the Start page to load the FEM projects. So, you click on the links and what exactly happens then? Does it load the files? What does it show in the tree view? To me this sounds rather a packaging issue than a bug in FreeCAD. Can you check which netgen version the FreeCAD package links to? When loading the 3D FEM project you can run this snippet in the Python console:
which should have this output:Box Box_Mesh FemConstraintFixed FemConstraintForce MechanicalMaterial CalculiX Analysis CalculiX_static_results |
[updated] Hello Werner, with _current_ git Packman version for my 'old' openSUSE 13.2 all is fine, after several weeks, again. What's _new_ is package 'med'?! (Got it in the last minutes with 'latest' FreeCAD.) 'netgen' was updated 2 or 3 times in the last two days, but was all the time version 6.0.99 git. Now I have this running fine: FreeCAD-0.16.99+git20160924.1611-4.1 netgen-6.0.99+git20160916.1332-2.1 med-3.2.0-4.1 Thanks, Dieter PS I use FreeCAD devel as one of my daily apps for Mesa 3D OSS driver (AMD) (regression) testing. PPS My biggest test file currently is 'bh.fcstd' from Yorik van Havre. Maybe there is some bigger more 'cleaner' one (e.g. oil rig) or the like with shaders? |
Could be closed, now. |
Nice to see it working now. My guess is that netgen was broken because a few weeks ago I was building netgen 6.x under Ubuntu and linked FreeCAD against it. Afterwards no FE mesh was visible. |
| 2016-09-18 01:59 | Dieter Nuetzel | New Issue | |
| 2016-09-24 16:26 | wmayer | Note Added: 0007326 | |
| 2016-09-26 01:22 | Dieter Nuetzel | Note Added: 0007335 | |
| 2016-09-26 01:23 | Dieter Nuetzel | Note Added: 0007336 | |
| 2016-09-26 13:14 | Dieter Nuetzel | Note Edited: 0007335 | |
| 2016-09-27 17:35 | wmayer | Note Added: 0007337 | |
| 2016-09-27 17:35 | wmayer | Status | new => closed |
| 2016-09-27 17:35 | wmayer | Resolution | open => no change required |
| 2016-09-27 17:35 | wmayer | Fixed in Version | => 0.17 |
