| 0002708 | Draft | Bug | public | 2016-09-25 09:42 | 2016-09-25 17:32 |
| Reporter | 0x221e | Assigned To | yorik | ||
| Platform | Linux x86_64 | OS | Arch Linux | ||
| Summary | 0002708: “Filled” checkbox doesn’t seem to have an effect when drawing a polygon in the Draft workbench | ||||
| Description | According to the wiki, checking/unchecking the “Filled” checkbox during the creation of a polygon in the Draft workbench “simply sets the View->Property of the Rectangle to "Flat lines" or "Wireframe"”. However, the (I assume, now corresponding) option, “Display Mode”, is set to “Flat Lines” regardless of the “Filled” setting. | ||||
| Steps To Reproduce | 1. Initiate drawing of a polygon in the Draft workbench 2. Enter arbitrary coordinates, make sure “Filled” is unchecked, and press “Enter point” 3. Enter an arbitrary radius, and press Enter 4. In the Combo View, “Display Mode” appears as “Flat Lines” | ||||
| Additional Information | OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8507 (Git) Build type: Release Branch: master Hash: cb3da6ff9c45fe5726ad0d17580ebe6636b3ea55 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.9.1 | ||||
| 2016-09-25 09:42 | 0x221e | New Issue | |
| 2016-09-25 17:31 | yorik | Note Added: 0007331 | |
| 2016-09-25 17:31 | yorik | Assigned To | => yorik |
| 2016-09-25 17:31 | yorik | Status | new => assigned |
| 2016-09-25 17:32 | yorik | Changeset attached | => FreeCAD Master master 72848a5a |
| 2016-09-25 17:32 | yorik | Status | assigned => closed |
| 2016-09-25 17:32 | yorik | Resolution | open => fixed |
