| 0002720 | FreeCAD | Bug | public | 2016-10-04 15:34 | 2016-10-04 21:00 |
| Reporter | DeepSOIC | Assigned To | DeepSOIC | ||
| Summary | 0002720: Scripts that use Part Extrude are broken | ||||
| Description | Recent changes to Part Extrude to use FaceMaker caused breakage of OpenSCAD importer. The culprit is that Extrude now treats Solid property as strict: if Solid is true, Extrude tries to use facemaker regardless of what is being extruded. Facemaker then fails, because it expects wires, not e.g. faces or shells. | ||||
| Steps To Reproduce | http://forum.freecadweb.org/viewtopic.php?f=10&t=17780 | ||||
| Additional Information | OS: Ubuntu 14.04.5 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.17.8576 (Git) Build type: None Branch: master Hash: 65a935f9ae164aa6857b77afcb2be6792435914c Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
FreeCAD: master d21f339a 2016-10-04 20:51:58 Details Diff |
Part: Extrude, Revolve: fix 0002720 - relax action of Solid=true When facemakers were introduced, Solid property of Revolve and Extrude was made strict: it calls facemaker if Solid==true, and facemaker would fail if shape being extruded/revolved is a face. This is fixed by testing there are no faces in source shape prior to calling facemaker. |
Affected Issues 0002720 |
| mod - src/Mod/Part/App/FeatureExtrusion.cpp | Diff File | ||
| mod - src/Mod/Part/App/FeatureRevolution.cpp | Diff File | ||
| 2016-10-04 15:34 | DeepSOIC | New Issue | |
| 2016-10-04 15:34 | DeepSOIC | Status | new => assigned |
| 2016-10-04 15:34 | DeepSOIC | Assigned To | => DeepSOIC |
| 2016-10-04 15:36 | DeepSOIC | Note Added: 0007341 | |
| 2016-10-04 21:00 | DeepSOIC | Changeset attached | => FreeCAD Master master d21f339a |
| 2016-10-04 21:00 | DeepSOIC | Status | assigned => closed |
| 2016-10-04 21:00 | DeepSOIC | Resolution | open => fixed |
