| 0000275 | FreeCAD | Bug | public | 2011-02-21 23:50 | 2011-05-17 07:27 |
| Reporter | andrewfrueh | Assigned To | |||
| Summary | 0000275: Cannot start program | ||||
| Description | I installed via the packaged installer "FreeCAD_0.10.3531_x86_setup.msi", and when I try to start the program I get this error: "The application failed to initialize properly (0xc0150002). Click on OK to terminate the application)" | ||||
| Additional Information | I have this same problem with either 0.10 or 0.9. Neither will work for me. I am using: Win XP Pro and Python 2.7. I am able to run Blender (v2.49b) just fine. | ||||
Is the PYTHONPATH variable set on you system? This would force FreeCAD to use the 2.7 lib directory while its compiled with 2.6.... |
I did not, but then tried setting PYTHONPATH to ... C:\Python27 and C:\Python27\Lib ... neither fixed the above error |
Mhh, without further information its hard to say... This packages are installed a thousand time. Is something unusual on your box? |
okay, thanks. I will explore the forum. Consider this issue closed. |
No further feedback, there fore closing. |
| 2011-02-21 23:50 | andrewfrueh | New Issue | |
| 2011-02-22 08:31 |
Note Added: 0000628 | |
| 2011-02-22 08:31 |
Assigned To | => Jriegel |
| 2011-02-22 08:31 |
Status | new => feedback |
| 2011-02-22 23:26 | unauthenticated | Note Added: 0000633 | |
| 2011-03-07 21:19 |
Note Added: 0000705 | |
| 2011-03-09 15:45 | unauthenticated | Note Added: 0000715 | |
| 2011-05-17 07:27 |
Note Added: 0000825 | |
| 2011-05-17 07:27 |
Status | feedback => closed |
| 2011-05-17 07:27 |
Resolution | open => unable to reproduce |
