| 0002756 | FreeCAD | Bug | public | 2016-11-03 10:12 | 2016-11-04 18:27 |
| Reporter | ruchg | Assigned To | yorik | ||
| Platform | Linux on x86 | OS | Fedora | OS Version | 23 |
| Summary | 0002756: Keyboard shortcut to rotate view 90 degrees. | ||||
| Description | The manual lists several keyboard shortcuts in "Navigating in the 3D view" page 31 in mine "CTRL + and CTRL - to zoom in and zoom out" "The arrow keys to shift the view left/right and up/down" seem to work as advertised However: SHIFT + left arrow and SHIFT + right arrow to rotate the view by 90 degrees does not. Instead it seems to pan the object left/right. I'm assuming the author means press and hold <shift> key, press and hold the <+> key and press and release the cursor arrow key. I've tried two different shift keys and two different plus keys. Instead of rotating the object 90 degrees the model just pans. This, at the end, points to a GitBook http://www.freecadweb.org/wiki/index.php?title=Manual:Introduction The GitBook: https://www.gitbook.com/book/yorikvanhavre/a-freecad-manual/details Or: https://yorikvanhavre.gitbooks.io/a-freecad-manual/content/discovering_freecad/navigating_in_the_3d_view.html#the-freecad-3d-view It needs to be determined if the documentation is incorrect, or if the keyboard shortcut is broken. This was posted to the forum and another user replied they were experiencing the same issue, so it is not localized to one machine. | ||||
| Additional Information | OS: Linux (Linux linuxHost.ruchg.net 4.6.4-201.fc23.x86_64 #1 SMP Tue Jul 12 11:43:59 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.Unknown Build type: Unknown Python version: 2.7.11 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 | ||||
| 2016-11-03 10:12 | ruchg | New Issue | |
| 2016-11-04 18:26 | yorik | Changeset attached | => FreeCAD Master master 0ea73730 |
| 2016-11-04 18:26 | yorik | Assigned To | => yorik |
| 2016-11-04 18:26 | yorik | Status | new => closed |
| 2016-11-04 18:26 | yorik | Resolution | open => fixed |
| 2016-11-04 18:27 | yorik | Note Added: 0007441 |
