| 0002760 | FreeCAD | Bug | public | 2016-11-06 11:13 | 2016-11-06 20:07 |
| Reporter | MajorTesla | Assigned To | |||
| Priority | immediate | Severity | major | Reproducibility | always |
| Platform | PC | OS | Windows | OS Version | 10 |
| Summary | 0002760: The result of an 'Undo' is shown too late. | ||||
| Description | If the Undo button is pressed after exiting the sketch mode, nothing seems to happen to the sketch but the undo action has actually been carried out. It becomes apparent if another action, such as 'Pad a selected sketch' is selected. | ||||
| Steps To Reproduce | 1. Open FC 2. Create empty document. 3. Create new sketch. 4. Draw a large rectangle. 5. Draw an arc. 6. Draw a straight line. 7. Constrain one line end to one arc line end. 8. Constrain other line end to other arc line end. 9. Close sketch. 10. Select 'Undo' (or Ctrl-Z) - nothing seems to happen to the 'sketch'! 11. Select 'Pad a selected sketch' and the previous 'Undo' action is only now apparent i.e. a coincident constraint is broken and the 'Pad' action can not be carried out. 12. Also, if you now go back to 'Edit' sketch, the 'Redo' menu button is inactive (greyed-out) so the 'Undo' action can not be reversed. | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6706 (Git) Build type: Release Branch: releases/FreeCAD-0-16 Hash: f86a4e411ff7848dea98d7242f43b7774bee8fa0 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| 2016-11-06 11:13 | MajorTesla | New Issue | |
| 2016-11-06 11:13 | MajorTesla | File Added: FreeCAD-Undo-prob.jpg | |
| 2016-11-06 20:06 | wmayer | Changeset attached | => FreeCAD Master master 57db39bf |
| 2016-11-06 20:07 | wmayer | Status | new => closed |
| 2016-11-06 20:07 | wmayer | Resolution | open => fixed |
| 2016-11-06 20:07 | wmayer | Fixed in Version | => 0.17 |
