| 0002771 | FreeCAD | Bug | public | 2016-11-14 15:10 | 2016-11-17 10:02 |
| Reporter | HoWil | Assigned To | |||
| Summary | 0002771: patharray not working in 0.17; settings missing | ||||
| Description | Patharray is not functional on my version of 0.17. In the Data-view only 'Base' and 'Path Obj' are visible all other settings like 'Align' are missing (compare http://www.freecadweb.org/wiki/index.php?title=Draft_PathArray#Technical_Explanation). The base object and the path are also not accepted when the were selected before using patharray. Still working in 0.16 (6453). The array is not shown when opening an FC file saved in 0.16 including an patharray. Given error message when starting FC from terminal and reproducing the patharray example listed. Running the Python command 'Draft_PathArray' failed: Traceback (most recent call last): File "/usr/lib/freecad-daily/Mod/Draft/DraftTools.py", line 4253, in Activated self.proceed() File "/usr/lib/freecad-daily/Mod/Draft/DraftTools.py", line 4267, in proceed Draft.makePathArray(base,path,defCount,defXlate,defAlign,pathsubs) File "/usr/lib/freecad-daily/Mod/Draft/Draft.py", line 1103, in makePathArray _PathArray(obj) File "/usr/lib/freecad-daily/Mod/Draft/Draft.py", line 5289, in __init__ obj.addProperty("App::PropertyLinkSubList","PathSubs",QT_TRANSLATE_NOOP("App::Property","Draft","Selected subobjects (edges) of PathObj")) | ||||
| Steps To Reproduce | Insert a cylinder in part design; draw a arc in Draft-wb; select cylinder and arc and use patharray. -> No patharray is created; Settings are missing. | ||||
| Additional Information | OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8922 (Git) Build type: None Branch: master Hash: 7f58ad2a4bbf0daad18cf59dddf32befeca1b60a Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
FreeCAD: master 3ce0de62 2016-11-17 02:59:33 Details Diff |
Fix 0002771 handling of PropertyLinkSubList in Draft.PathArray |
Affected Issues 0002771 |
FreeCAD: master 83444cc4 2016-11-17 11:02:04 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000340 from WandererFan/PathArray17 Fix 0002771 handling of PropertyLinkSubList in Draft.PathArray |
| 2016-11-14 15:10 | HoWil | New Issue | |
| 2016-11-17 10:02 | wandererfan | Changeset attached | => FreeCAD Master master 3ce0de62 |
| 2016-11-17 10:02 | Changeset attached | => FreeCAD Master master 83444cc4 | |
| 2016-11-17 10:02 | guest | Status | new => closed |
| 2016-11-17 10:02 | guest | Resolution | open => fixed |
