| 0002789 | Path | Bug | public | 2016-11-20 19:56 | 2016-11-21 09:21 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0002789: G-code export via File menu broken | ||||
| Description | When trying to export the g-code of a job via the menu "File->Export" an exception is hit: PathScripts.linuxcnc_post gcode postprocessor loaded. Traceback (most recent call last): File "<string>", line 4, in <module> <type 'exceptions.RuntimeError'>: export() takes exactly 3 arguments (2 given) And no output is produced. | ||||
| Additional Information | This is an oversight in the changes made to PathPost in order to support arguments to the post processor script. | ||||
FreeCAD: master 31d43b4a 2016-11-21 10:20:11 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000344 from mlampert/FileExportPath Path: fix File menu g-code export, tracker 0002789 |
Affected Issues 0002789 |
| mod - src/Mod/Path/Gui/AppPathGuiPy.cpp | Diff File | ||
| mod - src/Mod/Path/Gui/DlgProcessorChooser.cpp | Diff File | ||
| mod - src/Mod/Path/Gui/DlgProcessorChooser.h | Diff File | ||
| mod - src/Mod/Path/Gui/DlgProcessorChooser.ui | Diff File | ||
| 2016-11-20 19:56 | mlampert | New Issue | |
| 2016-11-20 19:56 | mlampert | Status | new => assigned |
| 2016-11-20 19:56 | mlampert | Assigned To | => mlampert |
| 2016-11-21 09:21 | wmayer | Changeset attached | => FreeCAD Master master 31d43b4a |
| 2016-11-21 09:21 | wmayer | Status | assigned => closed |
| 2016-11-21 09:21 | wmayer | Resolution | open => fixed |
| 2016-11-21 09:21 | wmayer | Fixed in Version | => 0.17 |
