| 0002790 | Path | Bug | public | 2016-11-21 20:07 | 2017-01-31 17:50 |
| Reporter | Hackscribble | Assigned To | sliptonic | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002790: Finish depth gives incorrect results | ||||
| Description | Finish depth can be entered in pocket path dialog but the value is not saved and not acted upon. As a workaround, the finish depth can be entered in the data pane. However, the generated gcode has the passes in the wrong order. | ||||
| Steps To Reproduce | 1. Load "pocket-test-01.fcstd" 2. Double click on pocket in tree 3. Open "Depths" section of dialog 4. Enter 0.1mm in finish depth 5. Click OK to exit dialog 6. Repeat steps 2 and 3 - finish depth is showing 0.00mm 7. Click OK to exit dialog 8. Click on finish depth in data pane and enter 0.1mm 9. Click on post process to generate gcode 10. Inspect gcode - finish depth pass (-3.90mm) comes before final depth pass (-4.00mm) | ||||
| Additional Information | OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8963 (Git) Build type: None Branch: master Hash: af62262021cc4ade42f232d86e8b96b553307691 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
I have a fix pending in my 'cleanup' branch. This is a rewrite of the DepthParams.getDepths() method. I've also added an optional parameter for 'equalstep' which defaults to False. If equalstep is True, then the stepdown value will be recalculated so that 1) it is equal or less than the entered value, 2) all steps down are the same depth. 3) the total steps down is not increased. 4) The finish depth is unchanged. This is useful to ensure that the cutter is under the same load on all passes. For example: start_depth = 10 step_down = 3 z_finish_step = 0 final_depth = 0 equalstep=False --> depth =[7,4,1,0] eqalstep=True --> depth = [7.5, 5.0, 2.5, 0] This will still need to be implemented in the GUI to work. |
cleanup branch will merge with Pull Request 0000376. Please verify after that if everything is working as expected. |
Appears to be working correctly. |
| 2016-11-21 20:07 | Hackscribble | New Issue | |
| 2016-11-21 20:07 | Hackscribble | File Added: pocket-test-01.fcstd | |
| 2016-11-27 19:58 | sliptonic | Assigned To | => sliptonic |
| 2016-11-27 19:58 | sliptonic | Status | new => assigned |
| 2016-11-27 20:08 | sliptonic | Note Added: 0007493 | |
| 2016-12-11 20:28 | sliptonic | Note Added: 0007521 | |
| 2017-01-14 01:09 | sliptonic | Note Added: 0007744 | |
| 2017-01-14 01:09 | sliptonic | Status | assigned => resolved |
| 2017-01-14 01:09 | sliptonic | Fixed in Version | => 0.17 |
| 2017-01-14 01:09 | sliptonic | Resolution | open => fixed |
| 2017-01-31 17:50 | wmayer | Status | resolved => closed |
