| 0002795 | Draft | Feature | public | 2016-11-26 18:57 | 2021-02-06 06:45 |
| Reporter | TomV | Assigned To | yorik | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.0 |
| Summary | 0002795: Allow cherrypicking individual lines from a sketch when creating a wall | ||||
| Description | My current (noob) workflow is as follows: 1. create a single monster sketch with the floorplan of my house 2. then draw draft rectangle over the sketch lines to specify walls 3. then convert those draft rectangles into a wall It's not possible to select lines from the sketch directly, which makes step number 2 necessary. If you select a single line from the sketch and then press 'wall', all lines of the sketch are converted into a wall. My RFE is to make it possible to specify select lines from a sketch. | ||||
| Steps To Reproduce | N/A | ||||
| 2016-11-26 18:57 | TomV | New Issue | |
| 2016-11-29 14:14 | yorik | Note Added: 0007498 | |
| 2016-11-29 14:14 | yorik | Assigned To | => yorik |
| 2016-11-29 14:14 | yorik | Status | new => assigned |
| 2018-01-12 15:31 | yorik | Target Version | => 0.18 |
| 2019-02-14 23:50 | yorik | Target Version | 0.18 => 0.19 |
