| 0002807 | Path | Bug | public | 2016-12-02 13:59 | 2017-01-09 21:50 |
| Reporter | Hackscribble | Assigned To | sliptonic | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002807: Cannot profile based on face | ||||
| Description | Creating profile based on face has stopped working. Creating path in tree and trying to add face gives Python error. | ||||
| Steps To Reproduce | Open test file "foo.fcstd". Select Path workbench. Click on "Path based on face" icon. When dialog opens, select top face of part and click "Add" under Base Geometry. | ||||
| Additional Information | Python error message ================= Profiling Select Mode Traceback (most recent call last): File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathProfile.py", line 595, in addBase self.obj.Proxy.addprofilebase(self.obj, sel.Object, i) File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathProfile.py", line 166, in addprofilebase self.execute(obj) File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathProfile.py", line 309, in execute output += self._buildPathLibarea(obj, edgelist, False) File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathProfile.py", line 197, in _buildPathLibarea curve = PathKurveUtils.makeAreaCurve(edgelist, direction, startpoint, endpoint) File "/usr/lib/freecad-daily/Mod/Path/PathScripts/PathKurveUtils.py", line 81, in makeAreaCurve if cleanededges[0].valueAt(cleanededges[0].LastParameter) in [cleanededges[1].valueAt(cleanededges[1].FirstParameter), cleanededges[1].valueAt(cleanededges[1].LastParameter)]: IndexError: list index out of range Version information =============== OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9114 (Git) Build type: None Branch: master Hash: fcd0465d8f891292dc03c95946b7ca8d51348857 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Problem does not happen in latest daily. Path is created correctly. Warning message apppears ... "DeprecationWarning: For future usage 'Curve' will return 'Line' which is infinite instead of the limited 'LineSegment'. If you need a line segment then use this: Part.LineSegment(edge.Curve,edge.FirstParameter,edge.LastParameter) To suppress the warning set BaseApp/Preferences/Mod/Part/General/LineOld to false" Using this version: OS: Ubuntu 16.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9139 (Git) Build type: None Branch: master Hash: adf3cc0f9547194e8002b84f7c3b08d5dc233307 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
bug was introduced by the 2D geom refactor and is resolved. |
| 2016-12-02 13:59 | Hackscribble | New Issue | |
| 2016-12-02 13:59 | Hackscribble | File Added: foo.fcstd | |
| 2016-12-05 09:59 | Hackscribble | Note Added: 0007512 | |
| 2016-12-11 20:25 | sliptonic | Note Added: 0007520 | |
| 2016-12-11 20:25 | sliptonic | Status | new => resolved |
| 2016-12-11 20:25 | sliptonic | Resolution | open => fixed |
| 2016-12-11 20:25 | sliptonic | Assigned To | => sliptonic |
| 2017-01-09 21:50 | wmayer | Status | resolved => closed |
| 2017-01-09 21:50 | wmayer | Fixed in Version | => 0.17 |
