| 0002809 | Path | Bug | public | 2016-12-03 23:03 | 2016-12-07 08:57 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0002809: Path visualisation of helixes is incorrect | ||||
| Description | A G2/G3 command represents a helix, yet it seems to be displayed as an arc in 3d space. Attached are two screenshots of the same Path, one taken from FC and the other taken from its output simulated by https://nraynaud.github.io/webgcode/ The FC version has errors on the bottom loop on both sides of the triangular cutout. A simulation of the actual g-code exported from that path does not show these errors and suggest that the Path itself is correct and this is a simple visualization error. | ||||
| 2016-12-03 23:03 | mlampert | New Issue | |
| 2016-12-03 23:03 | mlampert | Status | new => assigned |
| 2016-12-03 23:03 | mlampert | Assigned To | => mlampert |
| 2016-12-03 23:03 | mlampert | File Added: helix-fc.png | |
| 2016-12-03 23:04 | mlampert | File Added: helix-gc.png | |
| 2016-12-03 23:13 | mlampert | Description Updated | |
| 2016-12-07 08:57 | wmayer | Changeset attached | => FreeCAD Master master 26e1a240 |
| 2016-12-07 08:57 | wmayer | Status | assigned => closed |
| 2016-12-07 08:57 | wmayer | Resolution | open => fixed |
| 2016-12-07 08:57 | wmayer | Fixed in Version | => 0.17 |
