| 0000281 | FreeCAD | Feature | public | 2011-02-22 12:44 | 2011-09-17 06:24 |
| Target Version | 0.12 | Fixed in Version | 0.12 | ||
| Summary | 0000281: Fix constraint | ||||
| Description | Add a constraint to the sketcher to fix a geometry to its position. | ||||
| child of | 0000278 | closed | Developing Sketcher |
Logari has implemented two fix constraints for x and y seperate. Work pretty well. But now the dragging of points has a problem. If dragged mostly the sketch dont solve. Dragging has to test different degrees of freedom. First try drag x,y and if fail try x and y seperately. Starting with the widest distance. |
I am working on this. |
Hi Logari, how is it going? Working on the new Solver? I have seen NaroCAD has also adopted the sketchsolve solver.. |
Is there an ETA on being able to create constraints between a sketch and features on the face it was created on? E.g. the abiliity to create a pocket on a face and constrain its position w.r.t the face that it's created on. From playing around with FreeCAD, this seems to be the biggist glaring hole. If support for this is added, I might actually be able to use freecad for a few things. |
external constraints are in our todo list but with voluntary work there is never an ETA. Btw. you are quite off topic here, please use the phpbb forum to ask about the progress of any feature. |
Well, I *was* going to post a new bug report about not being able to do that until I saw this bug which I thought was somewhat similar. I suppose I will just make a new bug report in the future then. |
resolved with logaris xy constraint |
Set to closed. |
| 2011-02-22 12:44 |
New Issue | |
| 2011-02-22 12:44 |
Assigned To | => Jriegel |
| 2011-02-22 12:44 |
Status | new => assigned |
| 2011-02-22 12:44 |
Target Version | => 0.12 |
| 2011-02-22 12:45 |
Relationship added | child of 0000278 |
| 2011-02-22 12:51 |
Relationship deleted | child of 0000278 |
| 2011-02-22 12:51 |
| 2011-06-02 12:17 |
Note Added: 0000880 | |
| 2011-06-03 05:19 | logari81 | Note Added: 0000881 | |
| 2011-06-04 12:10 |
Note Added: 0000882 | |
| 2011-09-06 01:09 | aforencich | Note Added: 0001041 | |
| 2011-09-06 06:26 | logari81 | Note Added: 0001042 | |
| 2011-09-06 06:41 | unauthenticated | Note Added: 0001043 | |
| 2011-09-16 04:59 |
Note Added: 0001090 | |
| 2011-09-16 04:59 |
Status | assigned => resolved |
| 2011-09-16 04:59 |
Resolution | open => fixed |
| 2011-09-16 05:02 |
Fixed in Version | => 0.12 |
| 2011-09-17 06:24 | wmayer | Note Added: 0001100 | |
| 2011-09-17 06:24 | wmayer | Status | resolved => closed |
