0002820FreeCADBugpublic2016-12-26 08:37
Reporterlanciaux Assigned To
PlatformLinuxOSSuseOS Version42.1 / 42.2
Product Version0.17
Fixed in Version0.17
Summary0002820: Expressions in every properties crash
DescriptionExpressions evaluation are crashing even on setting simplest object properties. Whatever you change by using an expression it fails ... crash with segfault.
Steps To Reproduce1. Open FreeCAD (latest DEV as GIT 9281)
2. Open Part WB
3. Draw a cube
4. go to edit property length : it is written 10 mm
4a. Click on fx() button
4b. over expressions edit line supplied : type simply 10+1
4c. hit enter
5. It should have crashed
Additional InformationIt has been a while (~ 3 months) I had noticed several issues. Before, it was arriving mostly after lot of work (hours) and/or several parts open, etc. I thought to myself it was memory corruption/error (or garbage collector issue). Before it was annoying if you save your work on a regular way ... now this is critical because Fx() is useless.
In past months, WB locations where it was crashing more often were those when you use expressions to calculate offsets in tools like PartDesign 'Create A Linear Pattern feature'
It is similar in sketch constrainst expressions.
Relationships
related to 0002819 closed Sketcher Using expressions in a constraint results in segfault
2016-12-19 18:57
administrator   ~0007532
No crash, neither under Ubuntu nor under Windows. Can you provide the stack trace of your crash?
lanciaux
2016-12-19 20:48
reporter   ~0007533
Here i my log (on another PC / Linux) :
lanciaux@linux:~/FreeCAD/_Build> FreeCAD -l
FreeCAD 0.17, Libs: 0.17R8907 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2016
Fasteners workbench Loaded
Sheet Metal workbench loaded
Erreur de segmentation
lanciaux
2016-12-19 20:49
reporter
FreeCAD.log (Attachment missing)
2016-12-20 17:01
administrator   ~0007535
Sorry, but the FreeCAD.log file is useless to find the reason. What I need is the stack trace that you can get with a debugger.
gdb ./FreeCAD
run
# reproduce the crash and then enter:
bt
lanciaux
2016-12-20 18:32
reporter
freecad_gcb_crash_test (Attachment missing)
lanciaux
2016-12-20 18:37
reporter   ~0007536
From GDB output it look it could be related to Boost - I will investigate (all my Linux are Suse based)
2016-12-22 11:42
administrator   ~0007546
Check if you are using boost 1.54. There is a known bug in this version and you should switch to a newer version e.g. 1.55 or later.
lanciaux
2016-12-25 21:07
reporter   ~0007549
Hello - I have checked 2 installs I was using : they were linked over boost 1.54 - I switch both to boost 1.61 devel and have not yet reproduced bug. Sorry for issue ... I try to close issue.
2016-12-26 08:37
administrator   ~0007550
I'll close the ticket.
2016-12-19 11:13 lanciaux New Issue
2016-12-19 18:57 wmayer Note Added: 0007532
2016-12-19 18:59 wmayer Relationship added related to 0002819
2016-12-19 20:48 lanciaux Note Added: 0007533
2016-12-19 20:49 lanciaux File Added: FreeCAD.log
2016-12-20 17:01 wmayer Note Added: 0007535
2016-12-20 18:32 lanciaux File Added: freecad_gcb_crash_test
2016-12-20 18:37 lanciaux Note Added: 0007536
2016-12-22 11:42 wmayer Note Added: 0007546
2016-12-25 21:07 lanciaux Note Added: 0007549
2016-12-26 08:37 wmayer Note Added: 0007550
2016-12-26 08:37 wmayer Status new => closed
2016-12-26 08:37 wmayer Resolution open => no change required
2016-12-26 08:37 wmayer Fixed in Version => 0.17
