0002856PathBugpublic2017-01-15 17:35
Reportermlampert Assigned Tomlampert
PlatformallOSallOS Versionall
Product Version0.17
Target Version0.17Fixed in Version0.17
Summary0002856: Contour operation fails if multiple jobs present in file
DescriptionIf a file contains multiple jobs a Contour operation in the second job fails with an exception "Somthing unexpected happened. Unable to generate a contour path. Check project and tool config"
IIRC Contour catches all underlying problems and issues above error instead.
mlampert
2017-01-14 02:21
developer   ~0007750
The description is misleading, I can reproduce the issue with only a single Job in the file. The problem seems to be related to the model.
mlampert
2017-01-14 02:41
developer   ~0007751
As it turns out the problem is that the model I'm using has notch (half circle) with a diameter exactly the same as the tool diameter. Slightly changing either one of them makes the problem go away.
The problem I see is one cannot "slightly change" the tool diameter in a real world setting. And once the model has been finalised, it might be rather hard to go back and change the radius, or even impossible depending in which format the model was given to machining.
mlampert
2017-01-15 17:35
developer   ~0007799
Closing this - the issue has nothing to do with there being multiple jobs
2017-01-14 01:36 mlampert New Issue
2017-01-14 02:21 mlampert Note Added: 0007750
2017-01-14 02:35 mlampert Note Edited: 0007750
2017-01-14 02:41 mlampert Note Added: 0007751
2017-01-15 17:35 mlampert Note Added: 0007799
2017-01-15 17:35 mlampert Status new => closed
2017-01-15 17:35 mlampert Assigned To => mlampert
2017-01-15 17:35 mlampert Resolution open => no change required
2017-01-15 17:35 mlampert Fixed in Version => 0.17
