| 0002865 | Path | Bug | public | 2017-01-17 19:26 | 2017-01-19 09:57 |
| Reporter | sliptonic | Assigned To | mlampert | ||
| Summary | 0002865: holding tag position indicators at wrong height | ||||
| Description | The position indicators (green balls) seem to be set at Z=0 by default instead of the Z height of the tag postiion. If the part is set with the top face at 0, this is obviously wrong. See attached image. Note, the tags are generated correctly. It's only the indicators at the wrong position. | ||||
| Steps To Reproduce | add a part. move part to a point below XY plane generate contour add holding tag dressup open dialog. | ||||
FreeCAD: master 4d5fab1e 2017-01-19 09:56:00 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000456 from mlampert/develop Path: fixes issue 2865 and 2854 |
Affected Issues 0002854, 0002865 |
| mod - src/Mod/Path/PathScripts/PathDressupHoldingTags.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathKurveUtils.py | Diff File | ||
| 2017-01-17 19:26 | sliptonic | New Issue | |
| 2017-01-17 19:26 | sliptonic | Status | new => assigned |
| 2017-01-17 19:26 | sliptonic | Assigned To | => mlampert |
| 2017-01-17 19:26 | sliptonic | File Added: snapshot-3.png | |
| 2017-01-19 09:57 | wmayer | Changeset attached | => FreeCAD Master master 4d5fab1e |
| 2017-01-19 09:57 | wmayer | Status | assigned => closed |
| 2017-01-19 09:57 | wmayer | Resolution | open => fixed |
| 2017-01-19 09:57 | wmayer | Fixed in Version | => 0.17 |
