0000297FreeCADBugpublic2011-03-09 08:46
Reporterjaguar98 Assigned To
Product Version0.11
Fixed in Version0.11
Summary0000297: Undo/Redo always disabled
DescriptionI tried 0.10 and 0.11, but both of them does not allow me to Undo or Redo. The Buttons are always disabled and the function never works (Not even if I press Ctrl+Z)
yorik
2011-03-03 23:50
administrator   ~0000683
Here undo/redo works fine...
Are you sure you enabled Undo/Redo in preferences?
Normally since 0.11 undo/redo is enabled by default, but if you installed a prior version of freecad you might still be using the user config files from earlier install, which have undo/redo disabled.
2011-03-04 07:36
administrator   ~0000684
Yes, you have to enable it under Edit > Preferences > General > Document > Using Undo/Redo on documents.
As Yorik said from version 0.11 on it's on by default but was off for previous versions and that's why it is still not activated because the old settings are stored in your user.cfg file.
2011-03-09 08:46
administrator   ~0000710
No bug, just a user setting issue.
2011-03-03 17:25 jaguar98 New Issue
2011-03-03 23:50 yorik Note Added: 0000683
2011-03-03 23:51 yorik Status new => feedback
2011-03-04 07:36 wmayer Note Added: 0000684
2011-03-09 08:46 wmayer Note Added: 0000710
2011-03-09 08:46 wmayer Status feedback => closed
2011-03-09 08:46 wmayer Resolution open => no change required
2011-03-09 08:46 wmayer Fixed in Version => 0.11
