| 0002975 | Path | Bug | public | 2017-03-19 01:13 | 2017-11-21 06:25 |
| Reporter | mlampert | Assigned To | mlampert | ||
| Summary | 0002975: Holding tags introduces wrong path segments | ||||
| Description | See attachments. The little circle is inserted at the boundary between a straight line an an arc. There is no holding tag in the neighbourhood, nor did changing the dressup configuration influence the error in any way. | ||||
| 2017-03-19 01:13 | mlampert | New Issue | |
| 2017-03-19 01:13 | mlampert | Status | new => assigned |
| 2017-03-19 01:13 | mlampert | Assigned To | => mlampert |
| 2017-03-19 01:13 | mlampert | File Added: contour.png | |
| 2017-03-19 01:13 | mlampert | File Added: holding-tags.png | |
| 2017-11-21 06:25 | mlampert | Status | assigned => closed |
| 2017-11-21 06:25 | mlampert | Resolution | open => unable to reproduce |
| 2017-11-21 06:25 | mlampert | Fixed in Version | => 0.17 |
| 2017-11-21 06:25 | mlampert | Note Added: 0010449 |
