| 0000300 | FreeCAD | Bug | public | 2011-03-05 10:01 | 2011-03-07 20:22 |
| Summary | 0000300: pad/pocket problem (when using pad/pocket on old sketch) | ||||
| Description | part design-> create a box->select a face (still in top view)-> create Sketch-> draw box -> Pad -> go to bottom view* draw a rectangle in sketcher close Sketcher -> go to right view -> draw a box in Sketcher -> Pocket -> select the sketch on the bottom face -> Pocket -> wired looking (pockets are gone) *(you should see another bug 0000299) FreeCAD_0.11.4193_x86_RC_bin.7z | ||||
Could you upload a screenshot, please? |
Why a screenshot when you can have a screencapture :) . https://rapidshare.com/files/451274117/pad_pocket.ogg |
Mhh, its actually no bug. You use a old sketch, so the support is on the shape with the one pad. The result of the second pocket is correct if you hide the first pocket. You basically forked your modeling line and have then two alternative ends... To avoid this create the next sketch on the last result. |
| 2011-03-05 10:01 | unauthenticated | New Issue | |
| 2011-03-06 14:39 | wmayer | Note Added: 0000695 | |
| 2011-03-06 14:39 | wmayer | Assigned To | => Jriegel |
| 2011-03-06 14:39 | wmayer | Status | new => assigned |
| 2011-03-06 19:34 | unauthenticated | Note Added: 0000697 | |
| 2011-03-07 20:22 |
Note Added: 0000701 | |
| 2011-03-07 20:22 |
Status | assigned => closed |
| 2011-03-07 20:22 |
Resolution | open => no change required |
