| 0003000 | FreeCAD | Bug | public | 2017-04-27 07:36 | 2017-04-27 17:20 |
| Reporter | Chris_G | Assigned To | wmayer | ||
| Platform | Linux | OS | Ubuntu | OS Version | 17.04 |
| Summary | 0003000: View property Angular Deflection can freeze FC | ||||
| Description | On some objects (like some BSpline surfaces). When trying to edit the Angular Deflection in the View tab. Deleting the numbers in front of the decimal separator freezes FreeCAD. The CPU goes 100%, the memory usage grows, and the FC windows becomes unresponsive. | ||||
| Steps To Reproduce | 1. Launch FreeCAD 2. Open the attached file 3. Select the object 4. Switch to the View Tab 5. Edit the Angular Deflection property 6. Delete the numbers in front of the decimal separator 7. FreeCAD freezes | ||||
| Additional Information | Happened in FC 0.17 (from PPA) with French locale, and ',' as decimal separator. Forum thread : Your text to link here... | ||||
| Tags | GUI | ||||
| 2017-04-27 07:36 | Chris_G | New Issue | |
| 2017-04-27 07:36 | Chris_G | File Added: Surface.fcstd | |
| 2017-04-27 07:36 | Chris_G | Tag Attached: GUI | |
| 2017-04-27 17:20 | wmayer | Changeset attached | => FreeCAD master 9aac25b7 |
| 2017-04-27 17:20 | wmayer | Note Added: 0008782 | |
| 2017-04-27 17:20 | wmayer | Assigned To | => wmayer |
| 2017-04-27 17:20 | wmayer | Status | new => closed |
| 2017-04-27 17:20 | wmayer | Resolution | open => fixed |
