| 0000303 | FreeCAD | Feature | public | 2011-03-08 07:57 | 2013-01-03 13:30 |
| Reporter | unauthenticated | Assigned To | mrlukeparry | ||
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000303: Draft feature in Part Design | ||||
| Description | I think FC should have "Draft Feature" (like this http://www.frotime.com/tutorials/solid_modeling/simple_draft_features.aspx). "Draft Feature" is very important in castings or forgings. Cheers, Kwahoo | ||||
| child of | 0000277 | closed | Further Development in PartDesign |
Hi, Your link gives 404 error. It is probably available only to subscribers Regards Petar Perisin |
Should be http://www.frotime.com/tutorials/solid_modeling/simple_draft_features.aspx (without bracket) |
make sense, have to look what cascade have in order for that. |
I have implemented this and have included a patch. It's nearly functional, however it still needs a fix on the mirrored extent and draft up to surface (there is no easy way to select the surface) but I am waiting for a way to show a preview of the pad... This we can also include for the pocket aswell, as it is very similar. This is best left for 0.13 release. |
were is the patch? |
It's on the developer disucssion some way back in the part design topic. I will have permanent internet on Thursday. I will get a fresh copy of free-cad from SVN and provide a fresh patch for you to try. For an actual draft tool that modifies 3d geometry, opencascade does have a draft feature where you can have a selection of faces, a neutral plane and specify a draft angle. It should be straight forward to create. Like before, I need a way to visualise the selection and a preview. |
In master there is now a draft feature. |
A Draft Feature is now included as a tool within Part Design. |
| 2011-03-08 07:57 | unauthenticated | New Issue | |
| 2011-03-08 14:13 | pperisin | Note Added: 0000707 | |
| 2011-03-08 14:20 | pperisin | Note Edited: 0000707 | |
| 2011-03-08 19:31 | unauthenticated | Note Added: 0000708 | |
| 2011-03-10 16:16 |
Status | new => assigned |
| 2011-03-10 16:16 |
Assigned To | => Jriegel |
| 2011-03-10 16:17 |
Relationship added | child of 0000277 |
| 2011-03-10 16:17 |
Target Version | => 0.12 |
| 2011-03-10 16:20 |
Note Added: 0000721 | |
| 2011-09-16 05:09 |
Target Version | 0.12 => 0.13 |
| 2011-09-17 18:26 | mrlukeparry | Note Added: 0001123 | |
| 2011-09-19 15:18 |
Note Added: 0001126 | |
| 2011-09-20 07:22 | mrlukeparry | Note Added: 0001127 | |
| 2012-10-18 14:34 | mrlukeparry | Assigned To | Jriegel => mrlukeparry |
| 2012-12-04 11:30 | wmayer | Note Added: 0002608 | |
| 2013-01-03 13:30 | mrlukeparry | Note Added: 0002789 | |
| 2013-01-03 13:30 | mrlukeparry | Status | assigned => closed |
| 2013-01-03 13:30 | mrlukeparry | Resolution | open => fixed |
| 2013-01-03 13:30 | mrlukeparry | Fixed in Version | => 0.13 |
