| 0003084 | PartDesign | Bug | public | 2017-06-16 02:06 | 2018-01-22 21:05 |
| Reporter | abdullah | Assigned To | abdullah | ||
| Summary | 0003084: PDN: Deleting features in the middle of the tree fails to update next features dependency (inlist) | ||||
| Description | Apparently when deleting a feature in the middle of a body, the features after the deleted feature are not linked to the previous feature anymore, they are assigned directly to body. NOTE: The features were deleted having Part WB active instead of PDN. It should not bear any significance, but it is here noted for completeness. | ||||
| Steps To Reproduce | 1. Do a PDN tree with several features. 2. Delete one feature in the middle. 3. The feature that was after the deleted feature now it is linked directly to body in the dependency graph, and will not continue the continuous solid from the previous feature. If it a pad it will just pad on thin air as if the previous features weren't there. | ||||
| Additional Information | Workaround: - Use PDN "move this object after object" functionality to regain the order. | ||||
| 2017-06-16 02:06 | abdullah | New Issue | |
| 2017-06-16 02:06 | abdullah | Status | new => assigned |
| 2017-06-16 02:06 | abdullah | Assigned To | => abdullah |
| 2018-01-11 14:26 | abdullah | Relationship added | related to 0003061 |
| 2018-01-13 18:35 | abdullah | Note Added: 0010759 | |
| 2018-01-15 15:42 | abdullah | Summary | PDN: Deleting features in the middle of the tree fails to update next features support => PDN: Deleting features in the middle of the tree fails to update next features dependency (inlist) |
| 2018-01-15 15:42 | abdullah | Description Updated | |
| 2018-01-15 15:42 | abdullah | Steps to Reproduce Updated | |
| 2018-01-22 20:11 | wmayer | Relationship added | related to 0003312 |
| 2018-01-22 21:05 | wmayer | Status | assigned => closed |
| 2018-01-22 21:05 | wmayer | Resolution | open => fixed |
| 2018-01-22 21:05 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-22 21:05 | wmayer | Note Added: 0010819 |
