| 0000031 | FreeCAD | Bug | public | 2009-11-02 18:26 | 2009-11-06 17:17 |
| Reporter | tdalla | Assigned To | |||
| Summary | 0000031: Compilation run properly but program crash when creating a new document | ||||
| Description | Hi, Here's my configuration: Linux Debian squeeze (testing) kernel 2.6.30-2-686 The compilation of the svn version (FreeCAD 0.9, Libs: 0.9R2237) run without any problem using cmake. When I start the program, everything looks ok (splash + interface) BUT, when I create a new document, FreeCAD crash with the following message: FreeCAD: ../../src/xcb_io.c:542: _XRead: Assertion `dpy->xcb->reply_data != ((void *)0)' failed. Abnormal program termination... Don't hesitate if you require aditionnal information Cheers, Thomas | ||||
Could you try to build with automake? The cMake support for Linux is not very stable so far. |
2009-11-04 20:17
I tried right now but the problem remains. I have joint the configure output. |
Were is the output? |
Works for me. I compiled it completely on Squeeze and used the freecad packages both works. There is a minor problem in Complete and Pivy but you can always open a document.... juergen |
| 2009-11-02 18:26 | tdalla | New Issue | |
| 2009-11-03 20:31 |
Note Added: 0000022 | |
| 2009-11-03 20:35 |
Status | new => feedback |
| 2009-11-04 20:17 | tdalla | File Added: FreeCad_Configure.out | |
| 2009-11-04 20:19 | tdalla | Note Added: 0000025 | |
| 2009-11-06 14:09 |
Note Added: 0000028 | |
| 2009-11-06 17:17 |
Note Added: 0000029 | |
| 2009-11-06 17:17 |
Status | feedback => closed |
| 2009-11-06 17:17 |
Resolution | open => unable to reproduce |
