| 0000310 | FreeCAD | Bug | public | 2011-03-15 19:20 | 2011-04-28 13:06 |
| Reporter | unauthenticated | Assigned To | yorik | ||
| Summary | 0000310: Shift does not work for distances | ||||
| Description | When you try to snap the "distancelines" (distance from draft module) horizontal/vertical by holding down the Shift key it won't work. FreeCAD_0.11.4221_x86_RC_bin.7z | ||||
You must hold shift between the first and the second point, so they are aligned... But I could indeed make it better so you can "rightify" a dimension after having picked its 2 points. |
"But I could indeed make it better so you can "rightify" a dimension after having picked its 2 points." That would be nice! |
done in r4463 |
| 2011-03-15 19:20 | unauthenticated | New Issue | |
| 2011-03-16 02:18 | yorik | Note Added: 0000737 | |
| 2011-03-16 02:18 | yorik | Status | new => assigned |
| 2011-03-16 02:18 | yorik | Assigned To | => yorik |
| 2011-03-16 19:34 | unauthenticated | Note Added: 0000739 | |
| 2011-04-28 13:06 | yorik | Note Added: 0000805 | |
| 2011-04-28 13:06 | yorik | Status | assigned => closed |
| 2011-04-28 13:06 | yorik | Resolution | open => fixed |
| 2011-04-28 13:06 | yorik | Fixed in Version | => 0.12 |
