| 0003109 | PartDesign | Bug | public | 2017-07-01 04:58 | 2017-07-01 08:06 |
| Reporter | kcleung | Assigned To | normandc | ||
| Platform | Linux | OS | Lubuntu | OS Version | 16.04 |
| Summary | 0003109: "remove ref" button in PartDesign fillet fails to remove selected edges | ||||
| Description | The fillet feature in PartDesign allows filleting multiple independent edges with a radius. "Add ref" can add edges. However, the "remove ref" button fails to remove edges. | ||||
| Steps To Reproduce | 1) Open the attached file (or alternatively create a body using PartDesign, then select two edges to make fillets) 2) In combo view, double click Body -> Fillet this will open the fillet window 3) Select "Edge 2", then click "remove ref" 4) Click "OK" The expected behaviour is that Edge 2 should disappear from the list, and when "OK" is pressed, edge 2 should no longer be filleted. However, none of these happens. | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11474 (Git) Build type: Unknown Branch: master Hash: 74e794002464b5230966bae86ce84409b0ee74fc Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | Part Design NEXT | ||||
Figured out that the correct procedure is to click "Remove ref" first before clicking the edge to the removed. So this is not a bug. Please close this bug |
| 2017-07-01 04:58 | kcleung | New Issue | |
| 2017-07-01 04:58 | kcleung | File Added: fail-to-remove-fillet-edges.fcstd | |
| 2017-07-01 04:58 | kcleung | Tag Attached: Part Design NEXT | |
| 2017-07-01 05:28 | kcleung | Note Added: 0009625 | |
| 2017-07-01 08:06 | normandc | Assigned To | => normandc |
| 2017-07-01 08:06 | normandc | Status | new => closed |
| 2017-07-01 08:06 | normandc | Resolution | open => no change required |
