| 0000315 | FreeCAD | Bug | public | 2011-03-20 20:09 | 2011-03-21 09:12 |
| Reporter | normandc | Assigned To | wmayer | ||
| Target Version | 0.12 | Fixed in Version | 0.12 | ||
| Summary | 0000315: New Circle tool in Sketcher causes problems editing Pad and Pocket features | ||||
| Description | The new circle tool in Sketcher causes instability with Pad and Pocket commands when editing their extrusion length. Case 1 (Pad) - start a sketch, draw a circle, create pad. On pad feature, change length to any dimension: the solid reverts to a surface cylinder opened on both ends. Case 2 (Pocket) - on an existing solid shape built with pad feature and any sketch drawing tool, select a face, start a sketch and draw a circle. Use the pocket command. Modifying the length of the pocket hangs FreeCAD indefinitely. | ||||
| Additional Information | FreeCAD 0.12.4285 from /trunk on Ubuntu 10.04.2 LTS 64-bit | ||||
Wanted to downgrade severity of the bug to minor but I'm not allowed to modify it. BTW a 0.12 series should be added to the bug report form. |
I see this error, strange! |
Yes, I can confirm both issues on Windows 7 64-bit. The first issue seems to be a problem with OCC's class BRepPrimAPI_MakePrism. But if go to edit mode and move the circle a little bit and recompute it the pad is fine again. |
The hanging happens inside BRepAlgoAPI_Cut which is called in Pocket::execute() |
This is definitely a bug in OCC but I found a nice work around. The point is that when re-computing the shape the missing parts of the cylinder have no valid tessellation and thus they appear empty. They only have a wire. And this is a direct consequence for the hanging of the pocket because the cut algorithm tries to compute the cut with a partially invalid shape. The solution is to make a copy of the sketch shape and use the copy. |
| 2011-03-20 20:09 | normandc | New Issue | |
| 2011-03-20 20:11 | normandc | Note Added: 0000741 | |
| 2011-03-21 07:58 |
Note Added: 0000742 | |
| 2011-03-21 07:58 |
Assigned To | => Jriegel |
| 2011-03-21 07:58 |
| 2011-03-21 07:59 |
Product Version | => trunk |
| 2011-03-21 08:06 | wmayer | Note Added: 0000743 | |
| 2011-03-21 08:06 | wmayer | Assigned To | Jriegel => |
| 2011-03-21 08:06 | wmayer | Status | acknowledged => new |
| 2011-03-21 08:17 | wmayer | Note Added: 0000744 | |
| 2011-03-21 09:06 | wmayer | Note Added: 0000746 | |
| 2011-03-21 09:07 | wmayer | Assigned To | => wmayer |
| 2011-03-21 09:07 | wmayer | Status | new => closed |
| 2011-03-21 09:07 | wmayer | Resolution | open => fixed |
| 2011-03-21 09:07 | wmayer | Fixed in Version | => trunk |
| 2011-03-21 09:07 | wmayer | Target Version | => trunk |
| 2011-03-21 09:12 | wmayer | Fixed in Version | trunk => 0.12 |
| 2011-03-21 09:12 | wmayer | Target Version | trunk => 0.12 |
