| 0003158 | Path | Bug | public | 2017-08-13 22:58 | 2018-01-29 20:01 |
| Reporter | mlampert | Assigned To | sliptonic | ||
| Summary | 0003158: Tool Cutting Edge Angle needs to be restricted to values 0° <= angle < 90° | ||||
| Description | Currently it is possible to add any angle, including negative angles. It is also an easy mistake for the user to manually double the angle and enter that error. All of the above lead to the wrong calculations, compensating most likely into the opposite direction. One way of mitigating that problem is prevention of entering an invalid angle in the first place. | ||||
| 2017-08-13 22:58 | mlampert | New Issue | |
| 2018-01-29 20:01 | sliptonic | Assigned To | => sliptonic |
| 2018-01-29 20:01 | sliptonic | Status | new => closed |
| 2018-01-29 20:01 | sliptonic | Resolution | open => fixed |
| 2018-01-29 20:01 | sliptonic | Fixed in Version | => 0.17 |
| 2018-01-29 20:01 | sliptonic | Note Added: 0010895 |
