| 0003167 | FEM | Bug | public | 2017-08-23 08:59 | 2018-01-04 09:50 |
| Reporter | HoWil | Assigned To | HoWil | ||
| Summary | 0003167: FEM - Materials dialogue - Units conversion problem | ||||
| Description | Values change in the dialogue boxes of a FluidMaterial and SolidMaterial in FEM-wb after one confirms with OK. When checking the values in python console (see below) or when reopening the material-dialogue one sees that the values are not the one entered (see also the two screenshots below). Some values are scaled (maybe converted wrongly) others are resetted to e.g. 1m^2/s. A similar but slightly different behavior can be observed with the SolidMaterial dialogue (see steps to reproduce). | ||||
| Steps To Reproduce | * Open FEM-wb and add an analysis and add a Solid-Material object * Edit the Solid-Material and change the Expansion Coefficient of e.g. Calculix-Stell from 12,00 µm/m/K to 12,5 µm/m/K * presses OK * reopen the dialogue and look for the changed value of 125 µm/m/K. | ||||
| Additional Information | The values are not only displayed this way... they are also stored as can be seen in the python-console: | ||||
| Tags | conversion, FEM, material, units | ||||
Here is the related forum post: https://forum.freecad.org/viewtopic.php?f=18&t=24015&sid=b38c4069377e364fe2fc6357141397e8 |
A related post: https://forum.freecad.org/viewtopic.php?f=18&t=24147&p=189667&sid=8bf8193f6a3dd98b9d8aa2ebaeda4f1a#p189664 |
https://github.com/FreeCAD/FreeCAD/commit/c309ea41 seems to fix the issue |
| 2017-08-23 08:59 | HoWil | New Issue | |
| 2017-08-23 08:59 | HoWil | File Added: FC_units_problem.fcstd | |
| 2017-08-23 08:59 | HoWil | File Added: Screenshots_material_dialogue.svg.png | |
| 2017-08-23 08:59 | HoWil | Tag Attached: FEM | |
| 2017-08-23 09:01 | HoWil | Note Added: 0009996 | |
| 2017-08-23 09:02 | HoWil | Tag Attached: material | |
| 2017-08-23 09:02 | HoWil | Tag Attached: units | |
| 2017-08-23 09:02 | HoWil | Tag Attached: conversion | |
| 2017-09-04 14:44 | HoWil | Note Added: 0010065 | |
| 2018-01-03 10:38 | berndhahnebach | Summary | Materials dialogue - Units conversion problem => FEM: Materials dialogue - Units conversion problem |
| 2018-01-03 10:39 | berndhahnebach | Summary | FEM: Materials dialogue - Units conversion problem => FEM - Materials dialogue - Units conversion problem |
| 2018-01-04 09:50 | wmayer | Assigned To | => HoWil |
| 2018-01-04 09:50 | wmayer | Status | new => closed |
| 2018-01-04 09:50 | wmayer | Resolution | open => fixed |
| 2018-01-04 09:50 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-04 09:50 | wmayer | Note Added: 0010698 |
