| 0003184 | PartDesign | Bug | public | 2017-09-15 17:15 | 2017-09-21 09:11 |
| Reporter | ickby | Assigned To | ickby | ||
| Summary | 0003184: PDN boolean fails to display result | ||||
| Description | When a PDN boolean is created and a PArt Feature added to it, the operation seems to work. However, no result is shown in the 3D view. | ||||
| Steps To Reproduce | 1.Create Part::Box 2.Move box by (5,5,5) 3.Create Body 4.Create Box Primitive 5.Select Part::Box 6.Add PD Boolean operation there should be a visible shape on the screen | ||||
The problem is the display mode. By default it uses the ViewProviderGeoFeatureGroups "Group" display mode, which shows the childs. It must be changed automatically to the body display mode. Note: check for all features if the body display mode is used by default, and make it universal if not |
https://github.com/FreeCAD/FreeCAD/commit/f1c307dc282df41300a3d05a11884826474275d6 |
| 2017-09-15 17:15 | ickby | New Issue | |
| 2017-09-15 17:15 | ickby | Status | new => assigned |
| 2017-09-15 17:15 | ickby | Assigned To | => ickby |
| 2017-09-15 17:34 | ickby | Note Added: 0010128 | |
| 2017-09-21 09:11 | wmayer | Status | assigned => closed |
| 2017-09-21 09:11 | wmayer | Resolution | open => fixed |
| 2017-09-21 09:11 | wmayer | Fixed in Version | => 0.17 |
| 2017-09-21 09:11 | wmayer | Note Added: 0010141 |
