| 0003185 | PartDesign | Feature | public | 2017-09-15 17:20 | 2017-12-10 16:48 |
| Reporter | ickby | Assigned To | ickby | ||
| Summary | 0003185: Recompute should work if only subgraph is cyclic | ||||
| Description | From werner: the recompute of the document now uses an own algorithm (Document::topologicalSort()) instead of boost graph. As part of PR 806 an algorithm was implemented also based on boost to detect sub-graphs that are valid DAGs in case the document has cycles so that at least a part of the document can be recomputed. Is this also possible with the new method? | ||||
| 2017-09-15 17:20 | ickby | New Issue | |
| 2017-09-15 17:20 | ickby | Status | new => assigned |
| 2017-09-15 17:20 | ickby | Assigned To | => ickby |
| 2017-12-03 07:14 | wmayer | Relationship added | related to 0002982 |
| 2017-12-10 16:48 | wmayer | Status | assigned => closed |
| 2017-12-10 16:48 | wmayer | Resolution | open => fixed |
| 2017-12-10 16:48 | wmayer | Fixed in Version | => 0.17 |
| 2017-12-10 16:48 | wmayer | Note Added: 0010560 |
