| 0000032 | FreeCAD | Bug | public | 2009-11-04 18:32 | 2009-11-27 08:12 |
| Reporter | wmayer | Assigned To | yorik | ||
| OS | Windows | ||||
| Fixed in Version | 0.9 | ||||
| Summary | 0000032: Draft tools don't work anymore | ||||
| Description | When using any command of the Draft toolbar there is an error message: Running the Python command 'Draft_Line' failed: Traceback (most recent call last): File "C:\Projekte\FreeCAD9\build\Mod\Draft\Draft.py", line 861, in Activated self.ui.translate("Pick first point:\n") 'Ui_draftToolbar' object has no attribute 'translate' And when trying to use a command in case there is now document open: Running the Python command 'Draft_Line' failed: Traceback (most recent call last): File "C:\Projekte\FreeCAD9\build\Mod\Draft\Draft.py", line 854, in Activated Creator.Activated(self) File "C:\Projekte\FreeCAD9\build\Mod\Draft\Draft.py", line 809, in Activated if not self.doc: self.finish() File "C:\Projekte\FreeCAD9\build\Mod\Draft\Draft.py", line 874, in finish Creator.finish(self) File "C:\Projekte\FreeCAD9\build\Mod\Draft\Draft.py", line 837, in finish self.ui.translate("") 'Ui_draftToolbar' object has no attribute 'translate' | ||||
| Steps To Reproduce | 1. Load Draft workbench 2. Create a new document (or not) 3. Press on one of the toolbar buttons | ||||
Oops, forgot to change a file... fixed in r2607 |
fixed in r2607 |
The one error is fixed now. But you still get an error message when trying to use a command if *no* 3d view is open. |
Funny, I thought I had solved that before... Anyway, I fixed it in r2608. I'd better keep this open until we make sure no more things happen... |
It seems to be really fixed. Thus, I close it again. |
| 2009-11-04 18:32 | wmayer | New Issue | |
| 2009-11-04 18:32 | wmayer | Status | new => assigned |
| 2009-11-04 18:32 | wmayer | Assigned To | => yorik |
| 2009-11-04 18:42 | yorik | Note Added: 0000023 | |
| 2009-11-04 18:43 | yorik | Note Added: 0000024 | |
| 2009-11-04 18:43 | yorik | Status | assigned => resolved |
| 2009-11-04 18:43 | yorik | Fixed in Version | => 0.9 |
| 2009-11-04 18:43 | yorik | Resolution | open => fixed |
| 2009-11-04 21:59 | wmayer | Note Added: 0000026 | |
| 2009-11-04 21:59 | wmayer | Status | resolved => feedback |
| 2009-11-04 21:59 | wmayer | Resolution | fixed => reopened |
| 2009-11-05 01:10 | yorik | Note Added: 0000027 | |
| 2009-11-27 08:12 | wmayer | Note Added: 0000041 | |
| 2009-11-27 08:12 | wmayer | Status | feedback => closed |
| 2009-11-27 08:12 | wmayer | Resolution | reopened => fixed |
