| 0000321 | FreeCAD | Bug | public | 2011-04-02 11:31 | 2011-05-18 07:39 |
| Summary | 0000321: Error on loading a document with a drawing | ||||
| Description | User report from the forum: Hello,everyone. I'm Japanese. so I can't written English precisely,approve it. I use FreeCAD for Windows 0.11/0.12 32bit and 64bit on Windows7 this is Bug Report for FreeCAD for Windows(0.11/0.12) at first,I saved FreeCAD(.FCStd) file within 3D and 2D data,and Execute close all. next,I open saved FreeCAD file within 3D and 2D data. Then, the following error message is indicated. could not open file 'c:/users/[username?]/AppData/Loal/Temp/FreeCAD_Doc_[???????-????-????-????-?????????/[filename].svg'. this case, I can't click error message Dialog's [OK] button. if relation file click and Open FreeCAD,then indicated message,but I can click error message Dialog's [OK] button. I checked .SVG file in indicated folder,but not found .svg file. I think that it will be modified someday. thank you. | ||||
| 2011-04-02 11:31 |
New Issue | |
| 2011-04-02 15:16 | normandc | Note Added: 0000764 | |
| 2011-05-17 13:42 |
Status | new => assigned |
| 2011-05-17 13:42 |
Assigned To | => Jriegel |
| 2011-05-17 13:43 |
Note Added: 0000841 | |
| 2011-05-17 13:43 |
Status | assigned => acknowledged |
| 2011-05-18 07:39 | wmayer | Note Added: 0000842 | |
| 2011-05-18 07:39 | wmayer | Status | acknowledged => closed |
| 2011-05-18 07:39 | wmayer | Resolution | open => fixed |
| 2011-05-18 07:39 | wmayer | Fixed in Version | => 0.12 |
