| 0000325 | FreeCAD | Bug | public | 2011-04-14 05:14 | 2011-05-17 13:10 |
| Reporter | davidjnice | Assigned To | |||
| Summary | 0000325: Crash when Duplicating a Part | ||||
| Description | When I use the 'Edit > Duplication Selection' on one 'part' that I've created Freecad crashes out. I've retested with other parts on the drawing and it works perfectly but on the part named 'eight_full-height', the duplication crashed Freedcad. I've run Freecad from a command prompt with the --log-file switch enabled and have attached the output for your reference. I've also attached the .fcstd file so that you can load up the file that I'm working with. I've also copied the eight_full-height block to another project and the same error happens. I'll delete and recreate the part so this won't be an issue for me but hopefully this information can help you with the project. | ||||
| Additional Information | Hi, I've just tried the same file on a Windows 7 installation with version 0.11 4237 2011/03/14 20:29:32 and I am able to duplicate the object so perhaps this issue has already been resolved? Also, it occours to me that the part is question is the only part I created by filleting a previos shape. The others were created from scratch. Could this be relavent information? | ||||
davidjnice said: I didn't finish adding the details before I caught update... I'm using Ubuntu Linux 10.04 with version 0.11 rev.3729 2010/11/14 18:37:35 deb from the sf page. Thanks! |
2011-04-14 05:18
2011-04-14 05:18
Could not reproduce the error and since the message in the log it seams a OpenGl problem again. There fore I close this bug now |
| 2011-04-14 05:14 | wmayer | New Issue | |
| 2011-04-14 05:15 | wmayer | Note Added: 0000780 | |
| 2011-04-14 05:15 | wmayer | Reporter | wmayer => davidjnice |
| 2011-04-14 05:15 | wmayer | Additional Information Updated | |
| 2011-04-14 05:18 | wmayer | File Added: freecadlog.txt | |
| 2011-04-14 05:18 | wmayer | File Added: mega-blocks.fcstd | |
| 2011-04-14 05:19 | wmayer | Note Edited: 0000780 | |
| 2011-05-17 13:10 |
Note Added: 0000838 | |
| 2011-05-17 13:10 |
Status | new => closed |
| 2011-05-17 13:10 |
Resolution | open => unable to reproduce |
