| 0003257 | Sketcher | Bug | public | 2017-11-12 11:48 | 2017-12-07 10:21 |
| Reporter | DeepSOIC | Assigned To | abdullah | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| OS | Windows | OS Version | 10 | ||
| Summary | 0003257: Can't apply vertical constraint - "this edge already has H-constraint" | ||||
| Description | Sometimes, FreeCAD refuses to apply vertical (or horizontal) constraint to an edge, if an endpoint of the edge participates in another vertical/horizontal constraint. | ||||
| Steps To Reproduce | 1. Load attached project 2. Open the sketch, select the line, and try applying Vertical Constraint to it -> error message, "This edge already has a horizontal constraint". Expected behavior is that the constraint should be applied. | ||||
| Additional Information | forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=25288 OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12539 (Git) Build type: Release Branch: master Hash: adc24f8c8ffb81ce5b85af9ac6ed67054ae0030d Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: Russian/RussianFederation (ru_RU) | ||||
| Tags | constraints, GUI | ||||
@abdullah I hope you don't mind I assigned the bug to you =) |
@DeepSOIC No problem at all. Eventually I will have time to code again and coding for FreeCAD is something I love to do ;) |
https://github.com/FreeCAD/FreeCAD/pull/1142 |
https://github.com/FreeCAD/FreeCAD/commit/4006c6ee97bde0f184d8d67a73fce308bb413f85 |
| 2017-11-12 11:48 | DeepSOIC | New Issue | |
| 2017-11-12 11:48 | DeepSOIC | Status | new => assigned |
| 2017-11-12 11:48 | DeepSOIC | Assigned To | => abdullah |
| 2017-11-12 11:48 | DeepSOIC | File Added: sketch-vertical-constraint-impossible.FCStd | |
| 2017-11-12 11:48 | DeepSOIC | Tag Attached: constraints | |
| 2017-11-12 11:48 | DeepSOIC | Tag Attached: GUI | |
| 2017-11-12 11:49 | DeepSOIC | Note Added: 0010412 | |
| 2017-11-14 13:15 | abdullah | Note Added: 0010417 | |
| 2017-12-06 16:06 | abdullah | Note Added: 0010518 | |
| 2017-12-07 10:21 | wmayer | Status | assigned => closed |
| 2017-12-07 10:21 | wmayer | Resolution | open => fixed |
| 2017-12-07 10:21 | wmayer | Fixed in Version | => 0.17 |
| 2017-12-07 10:21 | wmayer | Note Added: 0010538 |
