| 0003319 | Path | Bug | public | 2018-01-19 16:40 | 2018-01-22 18:44 |
| Reporter | sliptonic | Assigned To | mlampert | ||
| Summary | 0003319: Tool Controller not found when setting up new Operation | ||||
| Description | When setting up a new operation (contour, Face Profile, Drilling, MillFace) If the user has selected a sub-element like a face, the new operation is created but doesn't find the tool controller. The list is empty. If no subelement is selected, the TCs are found. A subelement can then be selected in the base geometry tab. Traceback (most recent call last): File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 99, in setEdit self.setupTaskPanel(TaskPanel(vobj.Object, self.deleteObjectsOnReject(), page, selection)) File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 108, in setupTaskPanel panel.setupUi() File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 882, in setupUi self.panelSetFields() File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 859, in panelSetFields page.pageSetFields() File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 211, in pageSetFields self.setFields(self.obj) File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 645, in setFields self.updateSelection(obj, FreeCADGui.Selection.getSelectionEx()) File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 693, in updateSelection if self.selectionZLevel(sel) is not None: File "/home/brad/FCD/FC/Mod/Path/PathScripts/PathOpGui.py", line 683, in selectionZLevel if PathGeom.isHorizontal(sub): <type 'exceptions.AttributeError'>: 'module' object has no attribute 'isHorizontal' | ||||
| Steps To Reproduce | 1) create a shape. 2) Start Path wb 3) select the Body and add a new Path Job. 4) select the top face of the shape and add a Face Profile operation. | ||||
| 2018-01-19 16:40 | sliptonic | New Issue | |
| 2018-01-19 16:40 | sliptonic | Status | new => assigned |
| 2018-01-19 16:40 | sliptonic | Assigned To | => mlampert |
| 2018-01-22 18:44 | wmayer | Status | assigned => closed |
| 2018-01-22 18:44 | wmayer | Resolution | open => fixed |
| 2018-01-22 18:44 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-22 18:44 | wmayer | Note Added: 0010816 |
