| 0003320 | Sketcher | Bug | public | 2018-01-20 22:41 | 2018-01-23 18:46 |
| Reporter | normandc | Assigned To | abdullah | ||
| Summary | 0003320: Rendering order not working with normal geometry when Sketch is fully constrained | ||||
| Description | The Rendering order widget works well when the sketch has remaining DOFs left. Placing normal geometry at the top of the list will display normal geometry over construction and external geometry. But as soon as the sketch is fully constrained, Normal geometry is rendered underneath construction and external geometry, no matter what the Rendering order is. | ||||
| Steps To Reproduce | 1. Open provided file FC017_Sketcher_Render_Order_Bug_normandc1.fcstd 2. Edit Sketch001 3. Set Normal Geometry to be first in the Rendering order list 4. The left and top normal lines (Edge2 and Edge3) are hidden underneath the external and construction lines (ExternalEdge1, ExternalEdge2, Edge5-Construction). 5. Delete one of the dimensional constraints: the normal geometry is brought to the foreground. | ||||
| Additional Information | Bug detected in the french forum topic https://forum.freecadweb.org/viewtopic.php?p=210630#p210623 Tested with self-compiled version OS: Ubuntu 16.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13062 (Git) Build type: Unknown Branch: master Hash: f6825a2686d80b0976c3d1900a9f56ce3c9f7d91 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: French/Canada (fr_CA) | ||||
Probably the longest commit in the history of FreeCAD: https://github.com/FreeCAD/FreeCAD/pull/1250 |
https://github.com/FreeCAD/FreeCAD/commit/c509ec5ded11385428e1a2d2e8a6e38cec8ab588 |
| 2018-01-20 22:41 | normandc | New Issue | |
| 2018-01-20 22:41 | normandc | File Added: FC017_Sketcher_Render_Order_Bug_normandc1.fcstd | |
| 2018-01-22 16:19 | abdullah | Assigned To | => abdullah |
| 2018-01-22 16:19 | abdullah | Status | new => assigned |
| 2018-01-23 16:00 | abdullah | Note Added: 0010823 | |
| 2018-01-23 18:46 | wmayer | Status | assigned => closed |
| 2018-01-23 18:46 | wmayer | Resolution | open => fixed |
| 2018-01-23 18:46 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-23 18:46 | wmayer | Note Added: 0010827 |
