| 0003325 | PartDesign | Bug | public | 2018-01-25 17:03 | 2018-02-09 23:48 |
| Summary | 0003325: Tip changes unexpectedly and cannot be restored | ||||
| Description | In fact I am not sure if this is one, two or even three bugs. In the attached file tipIssue1.FCStd the Tip gets lost, and cannot be restored. In tipIssue2.FCStd there are two bodies. The tip selection list shows elements from the first body only. | ||||
| Steps To Reproduce |
- Cancel the editing panel (no need to change any values) Tip has changed to Cylinder which is a bug. Tip cannot be set back because the list offered is empty - In the DataTab click the three dots at the right of the Tip Panel - Only elements from the first body are shown. | ||||
| Additional Information | Forum Discussion | ||||
TipIssue1 confirmed. Workaround: select pocket, right-click, set-tip. |
TipIssue2 confirmed. Same workaround works. |
will take a look this afternoon... |
https://forum.freecadweb.org/viewtopic.php?f=10&t=26624&sid=27e74c1fb93a748e4195426a813c0948 |
https://github.com/FreeCAD/FreeCAD/pull/1283 |
https://github.com/FreeCAD/FreeCAD/commit/a33ac385081d7b357a119b5bafa2c7b83624a642 |
| 2018-01-25 17:03 | chrisb | New Issue | |
| 2018-01-25 17:03 | chrisb | File Added: tipIssue1.FCStd | |
| 2018-01-25 17:03 | chrisb | File Added: tipIssue2.FCStd | |
| 2018-01-27 17:21 | abdullah | Assigned To | => abdullah |
| 2018-01-27 17:21 | abdullah | Status | new => assigned |
| 2018-01-28 10:44 | abdullah | Note Added: 0010884 | |
| 2018-01-28 10:45 | abdullah | Note Added: 0010885 | |
| 2018-01-28 10:45 | abdullah | Status | assigned => confirmed |
| 2018-01-28 10:45 | abdullah | Note Added: 0010886 | |
| 2018-01-28 17:37 | abdullah | Note Added: 0010887 | |
| 2018-02-01 15:08 | abdullah | Note Added: 0010909 | |
| 2018-02-09 23:48 | wmayer | Status | confirmed => closed |
| 2018-02-09 23:48 | wmayer | Resolution | open => fixed |
| 2018-02-09 23:48 | wmayer | Fixed in Version | => 0.17 |
| 2018-02-09 23:48 | wmayer | Note Added: 0010939 |
