| 0003336 | Path | Feature | public | 2018-02-01 16:20 | 2021-04-28 15:18 |
| Reporter | sliptonic | Assigned To | dubstar_04 | ||
| Priority | high | Severity | major | Reproducibility | have not tried |
| Target Version | 0.20 | Fixed in Version | 0.19 | ||
| Summary | 0003336: Tool Data Struture, Library, and Editor overhaul | ||||
| Description | Tool Geometry is used in tool path calculation but also in simulation. The current tool definition includes a number of properties like cutting edge angle cutting edge height diameter etc Only a couple properties are used at all and others are confusing, contradictory, or useless. A new structure is needed that can cover many different types of tools including drills, endmills, lathe tools, shell cutters, fly cutters, and others. | ||||
| Steps To Reproduce | An ideal solution will provide an extensible data structure that allows new kinds of tools to be added over time. The data gathered should drive a parametric modeling of the tool representation for simulation and visualization. Tool definitions and attributes should use industry standards whenever possible. | ||||
| Additional Information | https://forum.freecadweb.org/viewtopic.php?f=15&t=23879 https://forum.freecadweb.org/viewtopic.php?f=15&t=23917#p186875 https://forum.freecadweb.org/viewtopic.php?f=15&t=26698 | ||||
Show Preview of tool shape |
I suggest that we try to implement this standard: ISO 13399 (Cutting tool data representation and exchange) https://en.wikipedia.org/wiki/ISO_13399 |
ISO 13399 has come up before: https://forum.freecadweb.org/viewtopic.php?t=24927 The problem has been getting a copy of the standard. It's one of those that is not freely available and expensive. An ideal solution would be to implement iso 13399 as a standalone python library that could be used in FreeCAD but also other projects like linuxcnc |
My university library has a copy of the standard. Also, to follow a post on the forum, I've been able to download some documents from Sandvik on the file structure associated with the standard. I probably won't be able to implement a python library myself, but I'd be willing to help. |
Can I assign this to me? |
Following the toolbit overhaul for 0.19 I believe this issue can now be closed. |
| 2018-02-01 16:20 | sliptonic | New Issue | |
| 2018-02-02 11:24 | chrisb | Note Added: 0010913 | |
| 2018-05-02 19:57 | imtaurus94 | Note Added: 0011222 | |
| 2018-05-02 20:52 | sliptonic | Note Added: 0011224 | |
| 2018-05-02 21:20 | imtaurus94 | File Added: gtc-hierarchy-introduction-20150701.pdf | |
| 2018-05-02 21:20 | imtaurus94 | File Added: gtc-package-specification-2-0-0.pdf | |
| 2018-05-02 21:20 | imtaurus94 | Note Added: 0011225 | |
| 2018-05-02 21:21 | imtaurus94 | Note Edited: 0011225 | |
| 2019-01-22 05:11 | sliptonic | Status | new => feedback |
| 2019-01-22 05:11 | sliptonic | Target Version | 0.18 => 0.19 |
| 2019-08-21 10:05 | dubstar_04 | Note Added: 0013439 | |
| 2019-08-21 16:48 | dubstar_04 | Assigned To | => dubstar_04 |
| 2019-08-21 16:48 | dubstar_04 | Status | feedback => assigned |
| 2021-02-06 06:33 | abdullah | Target Version | => 0.20 |
| 2021-04-28 15:18 | dubstar_04 | Note Added: 0015645 | |
| 2021-04-28 15:18 | dubstar_04 | Status | assigned => closed |
| 2021-04-28 15:18 | dubstar_04 | Resolution | open => fixed |
| 2021-04-28 15:18 | dubstar_04 | Fixed in Version | => 0.19 |
