| 0003337 | TechDraw | Feature | public | 2018-02-04 13:47 | 2018-04-25 09:12 |
| Reporter | wandererfan | Assigned To | wandererfan | ||
| Summary | 0003337: Add Arbitrary Dimension | ||||
| Description | Forum discussion Add the ability to add a Dimension to a View that is linked to geometry (edge,vertex), but uses a user entered value. This could be useful, for example, to apply "radius" dimensions to spline curves. | ||||
| Tags | 0.18, TechDraw | ||||
This ticket should belong to TechDraw project, not FreeCAD project. |
My impression is that the forum discussion talks more about a callout than an arbitrary dimension. A callout can add any text string. The line and arrow attached to the callout note is called a "leader". Usually there's a break on the line, with a small segment close to the text note and parallel to it; or you can choose not to have a break. A callout would be very useful to have in TechDraw. (It's similar to Draft Label) https://en.wikipedia.org/wiki/Callout https://duckduckgo.com/?q=technical+drawing+callout&t=canonical&iax=images&ia=images |
Similar feature could be used for: * surface roughness: https://en.wikipedia.org/wiki/Surface_roughness * tolerances: https://en.wikipedia.org/wiki/Geometric_dimensioning_and_tolerancing (see datums and datum references) * tapers: https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Mechanical/files/GUID-B547792A-346F-40F7-9097-188904F5C3F8-htm.html * ... |
https://github.com/FreeCAD/FreeCAD/commit/a40996016f9768668a34d03495bb6aeffe092375 |
| 2018-02-04 13:47 | wandererfan | New Issue | |
| 2018-02-04 13:47 | wandererfan | Tag Attached: 0.18 | |
| 2018-02-04 13:47 | wandererfan | Tag Attached: TechDraw | |
| 2018-02-04 13:56 | wandererfan | Note Added: 0010917 | |
| 2018-02-04 13:58 | wandererfan | Project | FreeCAD => TechDraw |
| 2018-02-04 23:46 | normandc | Note Added: 0010918 | |
| 2018-02-04 23:48 | normandc | Note Edited: 0010918 | |
| 2018-02-26 09:09 | reox | Note Added: 0010984 | |
| 2018-04-25 09:12 | wmayer | Assigned To | => wandererfan |
| 2018-04-25 09:12 | wmayer | Status | new => closed |
| 2018-04-25 09:12 | wmayer | Resolution | open => fixed |
| 2018-04-25 09:12 | wmayer | Fixed in Version | => 0.18 |
| 2018-04-25 09:12 | wmayer | Note Added: 0011194 |
