| 0003343 | Path | Bug | public | 2018-02-09 13:28 | 2018-04-30 08:28 |
| Reporter | robinh | Assigned To | mlampert | ||
| Platform | PC | OS | any | ||
| Summary | 0003343: grbl post processor does not scale feed rate correctly on 13218 | ||||
| Description | See Help Forum When in Path-Job-Tools, there are 5 columns: Name, #, mm/s, mm/s and Spindle. I am not sure why two columns have the same header? Anyway, using the first column, I set my feed rate to 13.33 mm/s corresponding to 800 mm/min. | ||||
| Steps To Reproduce | See description. mm/s are set to 13.33. Look at last line in grbl gcode. The line includes F13.33. It should say F800. The 13.33 needs to multiplied by 60 to convert mm/s to mm/min | ||||
| Additional Information | May applies to LinuxCNC post processor too. It uses mm/min. I don't know feed rate units requirements of other post-processors. Work-around. In the dialog, set it to 800 not 13.333, then it outputs F800! | ||||
| 2018-02-09 13:28 | robinh | New Issue | |
| 2018-04-29 22:48 | mlampert | Assigned To | => mlampert |
| 2018-04-29 22:48 | mlampert | Status | new => assigned |
| 2018-04-30 04:31 | mlampert | Reproducibility | have not tried => always |
| 2018-04-30 04:31 | mlampert | OS | Windows => any |
| 2018-04-30 04:31 | mlampert | OS Version | 10 => |
| 2018-04-30 04:31 | mlampert | Fixed in Version | => 0.18 |
| 2018-04-30 04:31 | mlampert | Target Version | => 0.18 |
| 2018-04-30 04:33 | mlampert | Note Added: 0011218 | |
| 2018-04-30 04:33 | mlampert | Note Edited: 0011218 | |
| 2018-04-30 08:28 | wmayer | Status | assigned => closed |
| 2018-04-30 08:28 | wmayer | Resolution | open => fixed |
| 2018-04-30 08:28 | wmayer | Note Added: 0011219 |
