| 0003386 | Path | Bug | public | 2018-03-22 00:58 | 2018-03-22 18:49 |
| Summary | 0003386: Path Selection Plane does not produce correct output | ||||
| Description | Selection plane doesn't produce correct output on postprocess. The command is largely unused and should be removed and reimplemented later. | ||||
| Steps To Reproduce | Create job Add selection plane set plane to XZ post process the job. Output should contain G18 and does not. | ||||
| 2018-03-22 00:58 | sliptonic | New Issue | |
| 2018-03-22 00:58 | sliptonic | Status | new => assigned |
| 2018-03-22 00:58 | sliptonic | Assigned To | => sliptonic |
| 2018-03-22 18:49 | wmayer | Status | assigned => closed |
| 2018-03-22 18:49 | wmayer | Resolution | open => fixed |
| 2018-03-22 18:49 | wmayer | Fixed in Version | => 0.17 |
| 2018-03-22 18:49 | wmayer | Note Added: 0011052 |
