| Description | Currently freecad requires a user to select appropriate constraint tool to constrain an object. This is because no dimension tool exists, such a tool would automatically detect object type and apply appropriate constraint rather than causing user to select appropriate constraint tool every time they want to constrain an object. The dimension tool should remain enabled to permit user to dimension as many items as desired thus not having to toggle the tool for every item they need to constrain. |
