| 0000341 | FreeCAD | Bug | public | 2011-04-16 01:28 | 2011-09-17 13:58 |
| Reporter | windrogue | Assigned To | yorik | ||
| Priority | normal | Severity | text | Reproducibility | always |
| Summary | 0000341: print or type set margin error | ||||
| Description | when trying to print a copy of the getting started pages, the left margin was cut off through the block header in the middle of the "N" in interactive tour making the text nonsense and unreadable. | ||||
| Additional Information | I am and have been an aircraft maintenance professional (licensed FAA airframe and power plant mechanic, 1150 hour private pilot, aircraft owner) for the last 20-25 years, but I have also worked in computers in the silicon valley area in the early '80's as well as in manufacturing and engineering in High Vacuum, Laser's, Aircraft Simulator's, and as a Senior Buyer at Rockwell's Science Center in Thousand Oaks California. I am interested in your CAD CAM program for various design projects I would like to develop, as I tend to be a "generalist" is how my boss at Coherent Laser's named me because I have a diverse background in many disciplines as a tech, clerk, or support person, that has an eye for systems integration and logistics problems. I hope I can be of some use to your venture. Great Dane, the "Wind Rogue" | ||||
Hi Dane, I can confirm the printing problem and will fix it ASAP. Thanks for reporting. Thanks also for your help offer, actually reporting bugs like this one is already a big help! Cheers Yorik |
Okay this is now fixed. The "printable version" link at the bottom of the left sidebar still produces a strange appearance, but the printed result (either from the "printable version" or from directly printing the normal page) gives a correct result. I'm closing this bug report now, don't hesitate to reopen if more problems appear. |
| 2011-04-16 01:28 | windrogue | New Issue | |
| 2011-04-16 12:40 | yorik | Note Added: 0000791 | |
| 2011-04-16 12:40 | yorik | Status | new => assigned |
| 2011-04-16 12:40 | yorik | Assigned To | => yorik |
| 2011-04-16 13:19 | yorik | Note Added: 0000792 | |
| 2011-04-16 13:19 | yorik | Status | assigned => closed |
| 2011-04-16 13:19 | yorik | Resolution | open => fixed |
| 2011-04-16 13:19 | yorik | Fixed in Version | => trunk |
| 2011-09-17 13:58 | yorik | Status | closed => feedback |
| 2011-09-17 13:58 | yorik | Resolution | fixed => reopened |
| 2011-09-17 13:58 | yorik | Status | feedback => closed |
| 2011-09-17 13:58 | yorik | Resolution | reopened => fixed |
| 2011-09-17 13:58 | yorik | Fixed in Version | trunk => 0.12 |
