| 0000342 | FreeCAD | Feature | public | 2011-04-16 13:33 | 2011-04-24 14:19 |
| Target Version | 0.12 | Fixed in Version | 0.12 | ||
| Summary | 0000342: Change the Draft upgrade behaviour to produce a more intelligent Group object | ||||
| Description | When using the Draft upgrade tool on non-connected geometry, a Compound shape is produced. This behaviour should be changed to produce a more intelligent "block" object, where the individual components can still be retrieved. This "block" object could also be used to create linked copies of the original geometry, therefore approaching the traditional 2D block behaviour. | ||||
| 2011-04-16 13:33 | yorik | New Issue | |
| 2011-04-16 13:33 | yorik | Status | new => assigned |
| 2011-04-16 13:33 | yorik | Assigned To | => yorik |
| 2011-04-24 14:19 | yorik | Note Added: 0000800 | |
| 2011-04-24 14:19 | yorik | Status | assigned => closed |
| 2011-04-24 14:19 | yorik | Resolution | open => fixed |
| 2011-04-24 14:19 | yorik | Fixed in Version | => 0.12 |
